ben_tucka
#1 Posted : 11 July 2018 12:57:34(UTC)
ben_tucka
Was thanked: 32 time(s) in 30 post(s)
As above has anyone fitted the IL Motorsports braided brake lines as sold via MX5 Parts. Looking at getting some EBC greenstuff pads and braided brake lines for my mk3.5  and like the IL as they have the original mounting loops.
Also does anyone know the brake bleeding order on the MK3.5
Ben.
12 Plate Venture edition, Crystal White Pearlescent, 2.0L, Retractable Hard top
#2 Posted : 11 July 2018 21:25:20(UTC)
Was thanked: 714 time(s) in 676 post(s)
I've fitted a set of those and was impressed with the fit.
I'd bleed FR, FL, RL, RR. Then probably go round again in the same order.
Edited by user 11 July 2018 21:26:14(UTC)  | Reason: Not specified
NA: RS Limited (Special car)
ben_tucka
#3 Posted : 11 July 2018 21:43:10(UTC)
ben_tucka
Many thanks. I've now added this to my mods list think I will wait till the brake pads I have on atm are worn but I do need some better braking performance. Felt a bit of brake fade at the weekend.
Ben.
Keat63
#4 Posted : 13 July 2018 11:10:11(UTC)
Keat63
Was thanked: 139 time(s) in 130 post(s)
Interesting, as i find the brakes are second to none.
On a trip to Burnsall a few weeks ago, I almost missed a turn off, jumped on the brakes and pulled both our faces off.
Although to be fair, i don't do spirited driving so much.
In and around Wakefield.
ben_tucka
#5 Posted : 13 July 2018 11:23:29(UTC)
ben_tucka
TBH I think it just needs better brake pads, but thinking about getting braided lines while I'm in the wheel arches. as I'm also planning on painting the brake calipers as well. I'm either going original silver or white but mainly doing it to make it tidier again they are looking a bit blemished.
Ben.
raz128
#6 Posted : 13 July 2018 12:03:49(UTC)
raz128
If you're looking to improve brake performance with braided lines and new pads, i'd recommend getting yellowstuff pads or Roddison motorsport pads (which I've heard very good things about) instead of the Greenstuff.
ben_tucka
#7 Posted : 13 July 2018 12:34:11(UTC)
ben_tucka
Thought the Yellow stuff was for Track use mainly and green stuff for fast road? or have I got this completely wrong?
Cypher
#8 Posted : 13 July 2018 14:21:14(UTC)
Cypher
Was thanked: 87 time(s) in 78 post(s)
Well I had Yellow stuff fitted to the front and was recommended just to use the standard on rear. Those who have been in my MX5 have said quote "my God brakes are bloody good"
That is good enough for me.
John
If you find the post useful - press the "Thank" button above.
Sunny Norfolk............
2011 NC2 Miyako (Special Edition) PRHT in Aluminium Silver
Secretly customized...........ish
Davy F
#9 Posted : 13 July 2018 18:36:06(UTC)
Davy F
Was thanked: 38 time(s) in 30 post(s)
I have recently had the HEL lines fitted and there’s a very noticeable difference to brake pedal feel. I‘m using standard discs/pads and I really like the feel through the pedal now.
Edited by user 13 July 2018 18:37:18(UTC)  | Reason: Not specified
raz128
#10 Posted : 13 July 2018 18:58:13(UTC)
raz128
I've had yellowstuff on my last 3 mx5's which have all been used as daily cars as well as doing a few trackdays; the pads work fine from cold and work well at pace. Will deffo be trying Rodissons next.
Cant say I've tried mixing different pads front/rear, in my mind that would risk leading to improper brake balance due to different compounds and different behaviour at heat.
Edited by user 13 July 2018 18:58:58(UTC)  | Reason: Not specified
Geege
#11 Posted : 15 July 2018 08:10:30(UTC)
Geege
Was thanked: 8 time(s) in 8 post(s)
Ben.
Hi Ben
I fitted Goodridge hoses to mine that work really well with a much better feel but it wasn't without issues, basically the lines don't fit without modification to support brackets etc so I would avoid them if you're considering that brand, I reported the problems to Goodridge who acknowledged me but I don't think anything has changed. Whilst I was at it I removed, thoroughly cleaned/degreased the calipers all round and painted them red, looks nice I, and many friends, think
Geege attached the following image(s):
Rear Calipers 4.jpg (160kb) downloaded 15 time(s).
Wheel 1.jpg (148kb) downloaded 11 time(s).
Wheel 1a After.jpg (129kb) downloaded 9 time(s).
Wheel 1b After.jpg (146kb) downloaded 10 time(s).
Geoff Minhinett
2010 MK3.5 2.0 Sport Tech Coupe in Galaxy Grey (Extra Fun Car)
2002 MK2.5 1.8VVT in Brilliant Black (Fun Car) Sold
2015 Mercedes C220 in Silver (Family Car)
ben_tucka
#12 Posted : 16 July 2018 08:45:47(UTC)
ben_tucka
Originally Posted by: Geege Go to Quoted Post
Hi Ben
That's my thoughts for looking at the IL Motorsports version as they have the mounting bracket
What paint did you use for your brakes as they do look very nice.
Geege
#13 Posted : 16 July 2018 10:19:25(UTC)
Geege
It was Hammerite Red Smooth
Geoff Minhinett
ben_tucka
#14 Posted : 23 August 2018 09:38:27(UTC)
ben_tucka
Just to resurrect this can you tell me how many of the copper washers I need to fit the brake lines and any other parts I require as I'm unsure how many it uses and when I take it apart to find out it will be too late then :(
Ben.
#15 Posted : 23 August 2018 11:19:35(UTC)
8 copper washers, as a general rule they come with the kits.
ben_tucka
#16 Posted : 23 August 2018 11:28:41(UTC)
ben_tucka
Many thanks
According to the reviews on MX5 Parts reviews they dont seem to come with the IL motorsports ones.
Ben.
This page was generated in 0.662 seconds.
