GlasgowGuy
#1 Posted : 11 July 2018 22:50:29(UTC)
GlasgowGuy
Hey folks, my passenger side window is stuck half way. Pressing the switch in either direction does nothing (tried both driver and passenger door switch), driver window is working fine.
Did I read right that it's only likely to be a fuse issue if both windows don't respond? Oh well, at least it's not meant to rain tonight...
#2 Posted : 12 July 2018 05:22:58(UTC)
Was thanked: 714 time(s) in 676 post(s)
Passenger side window cut switch pressed? It’s under the 2 switches on the driver’s door IIRC.
NA: RS Limited (Special car)
GlasgowGuy on 12/07/2018(UTC)
Paul G
#3 Posted : 12 July 2018 05:43:36(UTC)
Paul G
Was thanked: 67 time(s) in 64 post(s)
As the depth of my pockets don't extend to an ND I'm going to assume that the window mech is at least similar to a Mk 2.5. (see pic)
The motor drives a drum which winds one cable while unwinding the other. This drum is nylon and has grooves for the cables to locate in.
When a cable breaks it springs back and twists itself up in the drum and jams, and basically self destructs.
Step one, check fuse.
Step two, see if you can lift the glass by hand. My cable drum jammed with the window 75mm down so I could lift the glass back to the top.
Step three, remove the door card and give the cables a tug to see if one is broken.
If it needs a new mech be prepared to loose some blood as it gets a bit tight for space in there.
Paul G
s/h mech from scrappy was still £50, but it worked.
 1 user thanked Paul G for this useful post.
IanH
#4 Posted : 12 July 2018 06:20:03(UTC)
IanH
Groups: AC, Administrators, ContentManagement, ForumModerator, OCACA_33, OCMember, Registered
Was thanked: 454 time(s) in 343 post(s)
This, most likely answer.
#5 Posted : 12 July 2018 06:57:50(UTC)
...apart from the fact that the button is in fact above the window switches, but below the mirror switch.
GlasgowGuy
#6 Posted : 12 July 2018 07:07:05(UTC)
GlasgowGuy
Embarassed - yet completely relived - to say that was it!
I was chatting to my friend outside the car at the time so I've hit the button while I was distracted. Had forgotten it even existed.
Thanks!
BarnsleyRob
#7 Posted : 12 July 2018 09:54:38(UTC)
BarnsleyRob
Was thanked: 18 time(s) in 17 post(s)
Lol, I know that feeling only too well. Glad it turned out to be a problem with the human interface !
2010 Mk3.5 in Copper Red
This page was generated in 0.783 seconds.
