DaveB63
#1 Posted : 14 September 2018 16:27:08(UTC)
DaveB63
Was thanked: 56 time(s) in 55 post(s)
Hi all. The trim that covers the stitching that holds the glass window onto my soft top is starting to peel away and I was wondering  what is the best type of adhesive  to use to re-stick it.The car is a 2.5 if that makes any difference
#2 Posted : 14 September 2018 16:45:19(UTC)
It's a very good question Dave and I really hope you get an answer because several of us would also really like to know.
DaveB63
#3 Posted : 14 September 2018 16:59:30(UTC)
DaveB63
Thanks for the reply Rob. I like to ask good  questions. It's not really important,but just another one of those niggling jobs to do
richardn
#4 Posted : 15 September 2018 13:27:25(UTC)
richardn
Was thanked: 234 time(s) in 228 post(s)
damn double postd
Edited by user 15 September 2018 13:29:23(UTC)  | Reason: Not specified
richardn
#5 Posted : 15 September 2018 13:27:26(UTC)
richardn
When we fitted hoods the glued sections were always done with impact adhesive (like Evostik)
Edited by user 15 September 2018 13:28:53(UTC)  | Reason: Not specified
 1 user thanked richardn for this useful post.
DaveB63 on 15/09/2018(UTC)
#6 Posted : 16 September 2018 09:02:22(UTC)
Was thanked: 652 time(s) in 577 post(s)
Gorilla Glue is recommended frequently over on the other forum (miataforum). Widely available here now.
 1 user thanked saz9961 for this useful post.
DaveB63 on 16/09/2018(UTC)
DaveB63
#7 Posted : 16 September 2018 09:13:04(UTC)
DaveB63
Thanks Saz. I often use a contact type glue in spray cans for sticking carpet tiles down at work. I was wondering about using that,but your suggestion  and the previous posters would be a lot less messy
#8 Posted : 16 September 2018 12:27:45(UTC)
The old yellow Evostick contact adhesive is excellent for a while, but eventually it tends to go brittle and crumbly, especially if exposed to UV, heat and flexing.
For example it was very effective repairing cuts etc on my ski jacket, (patch glued to the inside of the outer layer so only the hint of a slit was visible, sometimes reinforced by some similar coloured Tesa tape on the outside) and good for about five years then needed redoing.  After almost twenty years of three weeks a year the jacket was rotted by the high altitude sun and mostly green Tesa tape, so it was replaced.
https://www.amazon.co.uk/dp/B000KJP2MM/
Pollyanna
#9 Posted : 16 September 2018 15:39:12(UTC)
Pollyanna
Was thanked: 40 time(s) in 39 post(s)
I have seen a report somewhere that said this glue was useless. If you put a blob of it onto some wood for instance, and don't spread it about, just let it dry, then cut through it with a razor blade or Stanley knife it looks like the old Aero chocolate you used to buy. It is full of tiny holes making it weak as a result. I have used it but not happy with it after i used it on Wood. You will be able to get adhesives especially made for fabric etc, its just a case of finding it. Ask an Upholsterer, they will know.
 1 user thanked Pollyanna for this useful post.
DaveB63 on 17/09/2018(UTC)
Scottishfiver
#10 Posted : 16 September 2018 16:21:02(UTC)
Scottishfiver
Was thanked: 430 time(s) in 348 post(s)
Gorilla os OK for rough outside jobs, and very effective.
I've repaired a stone bird bath bowl with it for one thing.
But..you MUST wet the surfaces to activate it properly to provide the required H2O catalyst otherwise it just sets to a sort of toffee resin.
When wetted it expands into a sort of Caramac coloured foam as it cures.
I'd avoid using it for delicate applications.
What I would do, is pop into the famous Woolies website...and see what the pro's use.
Not checked myself, but for your convenience......
https://www.woolies-trim.co.uk/
 1 user thanked Scottishfiver for this useful post.
#11 Posted : 16 September 2018 16:40:53(UTC)
Check  Real World Experience on Miataforum, 109,000 registered used, 13,000 active users. The topic is is reference to gluing plastics and mohair-like materials, not wood.
For example:
https://forum.miata.net/vb/showthread.php?t=306138
https://forum.miata.net/vb/showthread.php?t=553989&
The reason why it failed for you is that you failed to follow the instructions. It's a water activated glue, so you have to lightly dampen down the surfaces. You didn't add any water.
https://www.youtube.com/watch?v=7Pxs6jFsp5s
Seems very strong to me. When properly used, your wood is going to break before the glue bond.
This page was generated in 0.385 seconds.
