3 Pages123>
foolhandy
#1 Posted : 20 August 2018 10:41:18(UTC)
foolhandy
Was thanked: 135 time(s) in 108 post(s)
Tech Day is back again in 2018!
On Sunday 14th October members from across the region will be meeting at Ashfields Farm, Great Canfield, Dunmow, CM6 1LD courtesy of member Henry Pestell and his son Barry. Although I've put a link to the location on Google Maps I would recommend using the directions below once you're near the venue as satnav directions will send you the wrong way at the end...
The day starts at 9am and goes on until the jobs are completed.
All sorts of jobs can be completed on Tech Days, from basic maintenance through to major surgery. All work is completed by you (although there are always others members willing to lend a hand) with the expert assistance of former MX5-OC Technical Advisor Roadster Robbie available for advice, encouragement and double checking!
Members usually bring their own tools but if there’s something you don’t have let us know as someone will doubtless be able to lend it to you on the day.
It’s traditional that people bring along food to share. Tea, coffee and toilet facilities are all available on site.
If learning new skills and recouping your Owners Club membership fee in just a morning appeals please let Robbie know what you plan to do below so he knows what to expect on the day.
Some come for the work, some come for the socialising, but it’s always a great day - please join us!
Karl
Edited by user 14 October 2018 20:39:01(UTC)  | Reason: Details!
Glenda (BRG 1.8 NA).
“Holding on to anger is like grasping a hot coal and expecting someone else to get burned.”-Buddhaghosa
"The past is a terrible place to live."-Steve Hogarth "If you can't say something nice, don't say anything at all"-Thumper
Nathan
#2 Posted : 21 August 2018 22:09:46(UTC)
Nathan
Hi.
I'm in Ely and currently part of the Norfolk group however sit neatly between the Norfolk and Eastern groups in Ely.
I have never attended a Tech Day before and am thinking I may like to pop along and discuss an issue I am having with my MK2 10AE.
It drives well, true and straight. However when cornering if I apply/remove power the car turns in/out of the corner; its almost like torque steer that you can get on FWD cars.
I don't believe its under/over steer as it happens way below the limits of the car.
I have checked tires (put two new ones on), checked pressures, checked brakes, moved the alloys from front to back, had the tracking four wheel laser aligned by specialists and it still does it.
So I am thinking bushes, dampers or diff (perhaps engine mounts as this could cause weight shift). Would be great if someone could help me eyeball these things on the ramp.
Perhaps someone has some other ideas. Would also be great to have someone else drive the car too and get their opinion.
Nathan
#3 Posted : 21 August 2018 22:52:44(UTC)
Was thanked: 714 time(s) in 676 post(s)
I'd go to one of the Norfolk hands free tech days where they have a ramp and get their opinion then...
Eastern Region tech days are generally not diagnosic days, more service and repair days.
Edited by user 21 August 2018 22:54:56(UTC)  | Reason: Not specified
NA: RS Limited (Special car)
Geoff Walton
#4 Posted : 22 August 2018 00:24:22(UTC)
Geoff Walton
Was thanked: 208 time(s) in 112 post(s)
33rd tech day!
Here's a pic of the gathering at #1 in May 2004
Australia
 1 user thanked Geoff Walton for this useful post.
martin on 29/08/2018(UTC)
foolhandy
#5 Posted : 22 August 2018 03:01:04(UTC)
foolhandy
We wrote a bit for Soft Top Hardtop to mark the 30th. Here's the smaller version that went into the December 2016 Eastern Newsletter...it seems that, like the first recorded football match, there's some debate over when it all started!
Bit more info too...I can confirm that there will again be a sticker for each attendee!
foolhandy
#6 Posted : 22 August 2018 03:15:26(UTC)
foolhandy
Agreed. You're more than welcome to come along Nathan, but our 'Hands On' Tech Days are really aimed at getting known jobs done. If for example you wanted to change the bushes to see if that is the root of the problem, you could do this at a Tech Day yourself with Robbie there for guidance & support. (Disclaimer, I have no idea if changing bushes is a job that could realistically be completed within the timeframe of a Tech Day!) Norfolk's 'Hands Free' Tech Days would probably be better suited for finding out if the bushes need changing in the first place, howver.
Tech Days 34 & 35 (!) will take place in 2019.
Karl
foolhandy
#7 Posted : 22 August 2018 03:17:47(UTC)
foolhandy
Robbie, I'm putting myself down for a few cosmetic things - weather seal clips, gear stick gaitor etc. although I may have a high-level brake light that needs wiring in...
Edited by user 22 August 2018 03:21:05(UTC)  | Reason: Turning duplicate into new!
Geoff Walton
#8 Posted : 22 August 2018 07:12:47(UTC)
Geoff Walton
Senior moment, I forgot the autumn 2003 meet up
Australia
GB6030
#9 Posted : 03 September 2018 11:44:00(UTC)
GB6030
Hi Robbie,
I have a few jobs that need doing. I intend to fit a new fuel filter, oil filter and oil change on a mk2 along with fitting a clock to the dash.
Graham
Nathan
#10 Posted : 03 September 2018 20:50:17(UTC)
Nathan
Thanks Robbie/Karl, I will try to get to the next Norfolk one (the one coming up soon has switched to a Detailing day). Ta.
PhilGee
#11 Posted : 08 September 2018 05:27:25(UTC)
PhilGee
Was thanked: 80 time(s) in 77 post(s)
Hi Nathan, have you spoken to someone like Michael Cleverley (www.mx5expert.com)? Might be worth a call and he's not that far from you.
Phil
1995 Eunos 1.8 S-Special, Laguna/Perky Blue (6W), Black Racing Pro N1, MeisterR, RS Ltd sideskirts, Cusco roll cage, K&N - Eunice the Eunos
2006 Mazda MX5 NC, 2.0 Option Pack, Galaxy Grey (32S), Eibachs, Cobra Sport, Pipercross and a few other upgrades - now sold
人馬一体
 1 user thanked PhilGee for this useful post.
Nathan on 10/09/2018(UTC)
foolhandy
#12 Posted : 12 September 2018 11:52:34(UTC)
foolhandy
Details added...only a month to go!
Karl
AlBoy
#13 Posted : 13 September 2018 13:32:42(UTC)
AlBoy
Hi Robbie, I have recently joined the owners club and have fitted a bashcam to my MX5. I would like to wire it into a switched fuse rather than use the cigarette lighter socket. Is this something I could do on the 14th?
Allan
Just to say thank you to all in attendance today. Nice to meet you and thanks to Robbie for the info.
Edited by user 14 October 2018 15:27:35(UTC)  | Reason: Not specified
#14 Posted : 14 September 2018 20:39:07(UTC)
Shouldn’t be a problem, I’d wire it to the cigar lighter socket wiring.
ady
#15 Posted : 18 September 2018 14:53:10(UTC)
ady
Well by some miracle my Mk1 went straight through the MOT yesterday so i'd better pop along and get a couple of jobs sorted.
Most important jobs are to replace the indicator and light switches that I still haven't got round to doing and replace the cable on the drivers side electric window so I can open the window again (which will be a treat).
BlueFive - Alimba
#16 Posted : 18 September 2018 22:41:21(UTC)
BlueFive - Alimba
Hi Robbie,
I'm planning on fitting a TR lane roll bar on this tech day, I do have most of the tools except a punch. I'm not sure if my drill can reach the difficult areas.
I also know that I need to prepare the car by removing the self behind the seats.
As I got the roll bar as used, I got supplied with 8.8 grade bolts, are those the normal ones or I should get high-tensile ones?
Finally, do you think that this will be possible? Also let me know if I need anything else on the day...
Cheers!
Many Thanks! :)
foolhandy
#17 Posted : 25 September 2018 17:47:20(UTC)
foolhandy
Stickers have arrived...less than three weeks to go!
martin
#18 Posted : 25 September 2018 19:16:22(UTC)
martin
Was thanked: 368 time(s) in 277 post(s)
I have a flappy flap to fix.  Count me in..
martin
MX5OC Chairman
GB IRL F B MC I CH FL D AND E NL L
stephen.byatt
#19 Posted : 25 September 2018 22:16:10(UTC)
stephen.byatt
Groups: AC, OCACA_5, OCMember, Registered
Originally Posted by: BlueFive - Alimba Go to Quoted Post
Hi Robbie,
Cheers!
Many Thanks! :)
Hi Spiros
I did this a couple tech days ago. I'll bring the tools I used, just in case. And the knowledge of how to do it.
Stephen
MX5 Mk1 '97 Berkeley. Turbocharged. Nuff said.
Area Coordinator - Eastern.
stephen.byatt
#20 Posted : 25 September 2018 22:19:26(UTC)
stephen.byatt
Hi Robbie
As usual, I've got a list of jobs longer than both arms.
First, need to change the radiator to a bigger size. It keeps overheating on trackdays, leading the ME221 ECU to limit the revs to 5.5K. Assuming it fits around the intercooler pipes, shouldn't be too tricky.
I'd like to change the diff oil and gearbox oil. Again, shouldn't be tricky if I can get it raised level.
I *might* install an oil cooler, but not sure I'll have time for that.
S
Guest (4)
3 Pages123>
This page was generated in 0.806 seconds.
