Andrew5
#1 Posted : 11 October 2018 21:25:56(UTC)
Andrew5
Was thanked: 50 time(s) in 46 post(s)
Hi all,
Ordered a set of the Carbonmiata quited floor mats for my wife's MK3  through their European distributor Carbonhaus last week and they arrived this evening, they look like they are well made quality part. I had an initial quick fit of the drivers side  and it looks good but I have a couple of questions to anyone who has fitted their RHD mk3
what's the best way to fit the quilted mat around the footrest? Remove footrest completely or pierce two holes in mat and fit below footrest?
Also tuck under the side sill covers or not?
many thanks.
Edited by user 12 October 2018 08:11:40(UTC)  | Reason: Not specified
Jeff - jthspace
#2 Posted : 15 October 2018 09:26:51(UTC)
Jeff - jthspace
I fitted IL Motorsport ones to my Mk1 and definitely would sit them under the side sill covers (as on Mk1) as it will stop you catching them getting in and out. Personally I would retain the footrest, although sometimes annoying when declutching due to the offset pedal position, it is overall of benefit on longer runs.
Would like to see some photos when fitted as may do my Mk3.
Jeff
Edited by user 15 October 2018 09:27:53(UTC)  | Reason: Not specified
Eunos 1993. Import 2016. Cobalt exhaust, BBS RS 15" alloys, MeisterR coil-overs, wood steering wheel, new Mk1 leather seats, Style bar, jammer, mohair hood, glass HRW. LED lights. 139,000 kms. Mk4 2018 ND2 GT Sport Nav+ Eternal Blue/Sand leather.
Andrew5
#3 Posted : 15 October 2018 15:40:00(UTC)
Andrew5
So had a bit more time yesterday to fit the mats into the car, passenger side took round fifteen minutes to fit into place, seats and centre console don't have to be removed from car and I tucked the mat under the centre console, you may break a finger nail dong this but the fit is very good and tight and should stay in place, I did try and tuck under the sill trim but found this lifted the trim slightly out of place so for now is left untucked, looks fine and no issue with this though may just get some Velcro strips just to hold it.
The drivers side mat also fits very well, the issue I have is that IL Motorsport covers are fitted and the mat is designed to go over the footrest which is fine but with the IL cover fitted it looked a bit naff half covered up, I did try sandwiching the mat between the footrest and cover but I am a bit concerned that over time tension on the mat may cause it to wear or split, I could have also made a cut in the mat and tucked it behind and below the footrest but didn't want to risk slicing the new mat. So for now I have completly removed the footrest and will see how I get on with this if I don't like it I may refit but without the IL cover, I did however piece a small hole in the mat and used the lower 10mm nut as an anchor point for the carpet mat if needed
I also pierced another small hole for the carpet mat anchor point so if I use the carpet mats will stop this from moving around, again also on the drivers side tucked under centre console but left untucked at sill.
 Have been trying to attach an image on my iPad using post-image but can't seem to get it to work, will try again later
Edited by user 15 October 2018 15:58:29(UTC)  | Reason: Not specified
#4 Posted : 15 October 2018 16:00:24(UTC)
Sounds good, we need pics
Andrew5
#5 Posted : 15 October 2018 16:51:13(UTC)
Andrew5
url=https://postimages.org/][/url]
Edited by user 15 October 2018 16:54:53(UTC)  | Reason: Not specified
 1 user thanked Andrew5 for this useful post.
MickAP on 15/10/2018(UTC)
Andrew5
#6 Posted : 15 October 2018 17:04:17(UTC)
Andrew5
Jeff - jthspace
#7 Posted : 15 October 2018 17:44:46(UTC)
Jeff - jthspace
Looks excellent and a job well done.
#8 Posted : 15 October 2018 18:44:16(UTC)
They look quality,thanks for sharing.
Andrew5
#9 Posted : 15 October 2018 18:52:40(UTC)
Andrew5
I'm pleased, time will tell how well they last, haven't seen many fitted to RHD cars.
safetymatch
#10 Posted : 15 October 2018 20:46:01(UTC)
safetymatch
Was thanked: 225 time(s) in 202 post(s)
I do like them but, i can envisage the stitching getting very grubby and frayed.
Are they washable and are you going to protect them with over-mats?
As i said i do like them, i'm not trying to sound negative.
Edited by user 15 October 2018 20:46:50(UTC)  | Reason: Not specified
Marble White icon
GPS tracker fitted
Lang'd to WIM spec's
Ex 2.5vvt sport
Stebel horn
Vented bonnet
Suzuki Jimny,fun!
Andrew5
#11 Posted : 15 October 2018 21:12:19(UTC)
Andrew5
The  stitching looks durable, nylon thread maybe, stitching looks very neat and tidy they do seem they can handle normal wear and tear ok, yes they are washable and I imagine should be able to clean any debris out of footwells easily enough, ask me again in a few months time, these can be ordered in a variety of colours I almost ordered them in all black.
Yes i probably will still use the original mats on top, located the position of the mat anchor clip on drivers side and made a small slice in mat so I can fit original carpet mat on top without it sliding around.
heres a link
https://www.carbonmiata.com/shop/mazda-mx-5/floor-mats-quilted-design/
Havent checked yet but I wonder will they help to reduce noise level slightly? probably not
Maybe Santa will bring me a boot mat for Christmas.
Edited by user 15 October 2018 21:17:19(UTC)  | Reason: Not specified
This page was generated in 0.607 seconds.
