loulou 62
#1 Posted : 08 November 2018 18:53:07(UTC)
loulou 62
Woman
Hi,can anyone help me my mx5 2.5 2002 fob is playing up it will not unlock from outside but unlocks and locks when I use from the inside if I use the key to unlock the doors my alarm goes off
#2 Posted : 08 November 2018 19:46:05(UTC)
The remote unit that pairs with the fob is inside the car behind the glovebox. Perhaps the signal is weakened by a tired battery but enough to work when inside car.
I would change the remote battery or at least check the voltage is around 3.0 volts.
loulou 62 on 08/11/2018(UTC)
loulou 62
#3 Posted : 08 November 2018 19:52:33(UTC)
loulou 62
Woman
Put new battery in but it was a cheap make will go get another brand asap thanks
#4 Posted : 08 November 2018 20:11:16(UTC)
Originally Posted by: rhino666 Go to Quoted Post
The remote unit that pairs with the fob is inside the car behind the glove box. Perhaps the signal is weakened by a tired battery but enough to work when inside car.
Agreed.
A couple of years ago I bought a pair of 2032 cells at the local corner shop for the kitchen scales, these lasted a fortnight, and close examination showed they were not Duracells but fakes.  Proper cells (Duracell, Panasonic, etc) usually last well over two years in the scales.
Both the new fobs for our Mazda3 had a dead cell at about 18 months, despite the spare one living in a steel filing cabinet and unable to talk with the car!  The Mazda3 knew when the cell was low and asked for it to be changed!  Same fob as for the ND.
The NC fob cell tends to last for a bit longer maybe 24-30 months.
In each case with the fobs the cell tested at the correct voltage with a meter (almost no current), 3v, but having lost charge over time it could not source enough current to transmit - just like when an old car battery can no longer turn over the engine.
There are also a lot of fakes and out-of-date cells about, daft when one considers how cheap the good ones are.
#5 Posted : 08 November 2018 20:17:09(UTC)
I've seen a few comments recently about rogue cheap button batteries being sold - perhaps you were unlucky enough to buy one of those.
A voltage test with a multimeter, if you have one, should show if the battery any good.
Just read Richard's post above, so it seems that a voltage test will not work:-(
Edited by user 08 November 2018 20:19:55(UTC)  | Reason: Not specified
Gerryn
#6 Posted : 08 November 2018 23:58:52(UTC)
Gerryn
Was thanked: 492 time(s) in 420 post(s)
Last new battery for the fob I bought was several years ago, from a local dealer. Keep thinking I really should change it, but while the thoughts there, the effort isn't!
Bit like the toothpaste syndrome! The intention is there, but I forget - till it runs out!
Five is Alive 2002 Mk2.5 Sport, with added Mazda body kit, 15 inch Rota Circuit 8 with Toyos, rescued wood rim steering wheel from a crashed Arizona. Air intake mods to come (one day!) Hard Dog Deuce rollbar. and HT (permanent fixture!) - It's still a sportscar.
#7 Posted : 09 November 2018 00:19:12(UTC)
Was thanked: 705 time(s) in 668 post(s)
loulou62, are you saying that the keyless entry transmitter works when you are sitting inside the car but doesn’t work properly if you are outside it?
Edited by user 09 November 2018 00:23:43(UTC)  | Reason: Not specified
Any work you do to your car is entirely your own responsibility. If in doubt, you should check technical advice with an independent , qualified person who has seen your car.
NA: RS Limited (Special car)
ND: 1.5 Sport Nav Soft Top Soul Red Crystal (Wow! What a colour!)
loulou 62 on 09/11/2018(UTC)
loulou 62
#8 Posted : 09 November 2018 09:29:08(UTC)
loulou 62
Woman
Hi yes that's correct the boot opens from outside but it doesn't open or close the doors from the outside,if I sit in the car and use the fob it opens a closes the doors don't know what's going on,if I try to unlock it with key it opens but the alarm goes off not good in the morning.
Guest (3)
This page was generated in 0.492 seconds.
