Black Max
#1 Posted : 11 January 2019 17:20:57(UTC)
Black Max
Hi all, I have a problem with what appears to be mould stains across the front 3 inches of my NC mohair roof. It’s above the metal front support cross bar that clips on to the top of the windscreen.
When I release the roof from screen, I can put my hand up above the bar under the mohair cover, and feel some material bonded to the underside of the roof material.  The stains coming through the top of the roof appear to be only above this bonded material.
I have regularly kept to roof clean and have treated with Autoglym cleaner and sealer yearly, so am disappointed this is happening.
Has anyone had experiences of this?  Should I remove the bonded material? Any help appreciated, thanks.
Brilliant Black 2006 Mk3 NC 1.8 Soft Top.
richardn
#2 Posted : 12 January 2019 14:06:19(UTC)
richardn
Was thanked: 232 time(s) in 226 post(s)
The staining should not be coming through. "Mohair" fabric is 2 sheets of material with a rubber membrane in between, all bonded together
ChrisRs
#3 Posted : 12 January 2019 14:30:51(UTC)
ChrisRs
Was thanked: 196 time(s) in 159 post(s)
Can you post  a picture ? It might be easier to suggest a remedy. Cheers
Owner of 'ChrisRS Valeting & Detailing' (Bingley, West Yorks)
Previous: MX-5 2013 (NC) Mk3.75 1.8 'SE' in Crystal White
Now: Mazda MX-5 2018 (ND) Mk4 2.0 'Sport Nav' in Meteor Grey and Sand Leather + 'Go Perform' exhaust
Black Max
#4 Posted : 12 January 2019 17:21:49(UTC)
Black Max
Thanks ChrisRs for your reply. I cant work out how to post a couple of pictures (feeling a bit stupid!) can anyone give me a quick answer please?  Cheers.
Mad Malc
#5 Posted : 12 January 2019 18:11:08(UTC)
Mad Malc
Was thanked: 111 time(s) in 93 post(s)
 1 user thanked Mad Malc for this useful post.
Black Max on 13/01/2019(UTC)
Black Max
#6 Posted : 12 January 2019 21:35:35(UTC)
Black Max
Thanks Mad Malc, I've hopefully got it now.
Here are a couple of pictures showing the mould marks on the roof.  I have tried cleaning with a soft nail brush and Autoglym mohair roof cleaner with no success. Thanks for any advice anyone can give.
ChrisRs
#7 Posted : 13 January 2019 08:41:35(UTC)
ChrisRs
Looking at it, the mould will need killing off
Use my method and it should be ok again
Antibacterial wash and wet vac is essential:
How to clean and seal a Mohair Hood
(ChrisRS Valeting & Detailing)
A nice sunny day and not too cold is essential to aid drying
Equipment:
Large car soft bristle wash brush
Nail brush
Wet & Dry Vac .... set to wet
Dry vac
Bucket
1" Detailing Brush or 2" NEW Paintbrush
Container for the Sealant
MF cloth
Fabric/Convertible roof sealant..Renovo/Fabsil/ Similar products
Method
In the bucket, mix a mixture, using around 100ml of each of the following:
Johnsons Baby Bath or similar
Milton Sterilising fluid, to kill Algae spores
Bilt Hamber Surfex APC or similar All Purpose Cleaner
Warm water to 3" in the bucket
1. Wash the roof in sections with the soft brush and then lightly with the nail brush to remove ingrained dirt. Do not apply any pressure
2. Suck out the moisture with the Wet Vac
3. Allow to dry for an hour in the sun
4. Dry vac the roof and leave a little longer
When satisfied that the roof is dry...It doesn't take long...That's the nature of Mohair,
1. Pour the sealant into container and apply section by section with a 1" Detailing brush
2. Each section should be lightly wiped with the MF cloth after each section
3. Wipe any Sealant off the glass immediately, or mask and cover the windows, prior to starting
Your Hood should now look brand new again!!
Edited by user 13 January 2019 08:43:11(UTC)  | Reason: Not specified
 1 user thanked ChrisRs for this useful post.
Black Max
#8 Posted : 13 January 2019 12:20:42(UTC)
Black Max
Thanks ChrisRs, I will try that in a few days(?) time when the weather is suitable     I'll get back to you and let you know how I get on.  Cheers, Jeff.
 1 user thanked Black Max for this useful post.
ChrisRs on 13/01/2019(UTC)
This page was generated in 0.394 seconds.
