BRUCE225
#1 Posted : 10 February 2019 15:20:28(UTC)
BRUCE225
Was thanked: 21 time(s) in 21 post(s)
Just discovered a rather large paint chip on my lower arch and it's rusted about little finger nail size, the current weather is holding me back from doing anything major but should I be looking at doing a temporary fix until weather changes or just leave it, didn't know if spraying with WD40 or a dab of grease or anything would help.
#2 Posted : 10 February 2019 15:41:11(UTC)
The wing is made of very thin, high strength steel.
It may be that due to the lack of thickness there you are chasing your tail to repair it as you cannot get deep enough to remove the rust without going through the wing. It is common for that to happen at the indicator repeaters but I do not have a good feeling about it.
Bettabuilda
#3 Posted : 10 February 2019 15:54:33(UTC)
Bettabuilda
Might be worth using some rust converter? I've used KuRust on other 5's in the past with some success. Other products are available  scrape off loose rust (if there is any) then apply to the affected area.
EDIT;
dries dark blue/black so a perfect match Bruce!
Edited by user 10 February 2019 15:56:08(UTC)  | Reason: Not specified
#4 Posted : 10 February 2019 16:03:42(UTC)
Do as Barrie suggests above.
I did my wheel arches last year, better weather of course and ground the area back to clean metal, treated with POR15 then primer and top coat of paint. Always difficult to touch in a rust bleb but at least get something on it and if poss remove the rust until you can do a proper job.
#5 Posted : 10 February 2019 16:11:34(UTC)
Don't leave it exposed as the surface rust will become pitting which will create far more work.
I have used clear nail varnish or similar, not mine you understand, just to seal the damage and prevent accelerated rust until the warmer weather and a proper repair.
BRUCE225
#6 Posted : 10 February 2019 21:05:27(UTC)
BRUCE225
Thanks guys have some kurust in the garage just didn't know what to put on top after treatment..what about a dab of hammerite on it or touch up paint to see me into better weather just thinking what's in the garage at the moment car is only used in dry weather but unfortunately kept outside
trufflehunt
#7 Posted : 10 February 2019 21:16:14(UTC)
trufflehunt
Was thanked: 109 time(s) in 91 post(s)
Anything will do really.  If it's actually a stone chip, the Kurust converted top layer protects quite well.
If the rust is actually coming through from underneath, then the Kurust will last a week or so, and then the rust will ...
"Oh, hello, it's me again...."
1993 MX5 Mk1 1.6 UK Car
2002 VW Golf 1.9 TDI
Keat63
#8 Posted : 11 February 2019 09:06:01(UTC)
Keat63
Was thanked: 140 time(s) in 131 post(s)
Personally I wouldn't use hammerite, it can have a tendency to react with other paints.
If you plan on painting it in the summer, the last thing you need is to make it worse.
Using a fine wet N dry paper (2000 grit), plenty of water and a dab of washing up liquid on the paper, try and at least flat off the rough edges.
Kurust it and then maybe a dab of zinc primer on a small paint brush.
This should keep the salt out for a few months.
If its on the inside of the arch, then a tin of colour matched paint may suffice later in the year.
In and around Wakefield.
BRUCE225
#9 Posted : 11 February 2019 09:29:34(UTC)
BRUCE225
My mistake with seeing rust I was in shock when typing.It's the lower bottom of the wing about two inch up from all edges no bubbling around it,not the dreaded arch rust just a big stone chip. just stuck out like a sore thumb think it might have happened using works industrial power washer and got under a small chip making it bigger.
Edited by user 11 February 2019 09:41:47(UTC)  | Reason: Not specified
This page was generated in 0.595 seconds.
