GaryL
#1 Posted : 06 March 2019 07:58:36(UTC)
GaryL
Hi All
I have noticed that my steering wheel is off to the left when the wheels are straight so driving along in a straight line I have to have the wheel over to the right.
Any ideas on how to fix this?
Edited by user 06 March 2019 07:59:37(UTC)  | Reason: Not specified
File Attachment(s):
Dosthilldave
#2 Posted : 06 March 2019 08:07:39(UTC)
Dosthilldave
Was thanked: 8 time(s) in 8 post(s)
I also have this issue after fitting a refurbished wheel. Clearly the splines aren’t exactly the same wheel to wheel. It’s only about one degree but really spoils the new wheel.
the solution appears to be to re center by adjusting the track rod ends with the wheel centred. Simple job at most tyre centres
im waiting for full geo after fitting lowered springs and will look to sort it then
2006 Mk3 2.0l sport true red
Daily drive 3 series m sport shadow edition
Keat63
#3 Posted : 06 March 2019 08:27:50(UTC)
Keat63
Was thanked: 145 time(s) in 136 post(s)
It could be that someone had the steering wheel off before and fitted it in the position.
Mine was out slightly, (although not as much as yours) and was corrected during a 4 wheel alignment.
Whilst the tracking was true, one side track rod was adjusted longer than the other causing the wheel to be slightly out of whack.
You could take the steering wheel off and move it clockwise a couple of splines, just be careful of the airbag.
Edited by user 06 March 2019 08:29:14(UTC)  | Reason: Not specified
In and around Wakefield.
 1 user thanked Keat63 for this useful post.
GaryL on 14/03/2019(UTC)
GaryL
#4 Posted : 06 March 2019 08:38:17(UTC)
GaryL
Thanks guys
This is the original steering wheel and has never been removed so maybe I need to take it to a tyre centre. I am thinking of getting a new steering wheel later in the year so I'll make sure I don't end up with the same problem.
best
Gary
Dosthilldave
#5 Posted : 06 March 2019 09:42:03(UTC)
Dosthilldave
Any idea when this changed? It shouldn’t just move. Have you kerbed it recently to disturb the alignment? If so might be worth a closer look at the front end just in case.
 1 user thanked Dosthilldave for this useful post.
Paul W
#6 Posted : 06 March 2019 12:07:40(UTC)
Paul W
Was thanked: 183 time(s) in 172 post(s)
This problem normally occurs when track rod ends are replaced with new., if the steering wheel isn't properly centred before re-setting the tracking.
Edited by user 06 March 2019 12:08:33(UTC)  | Reason: Not specified
Mk2 1.8i, built Jan 1998.
 1 user thanked Paul W for this useful post.
Scottishfiver
#7 Posted : 06 March 2019 16:09:56(UTC)
Scottishfiver
Was thanked: 444 time(s) in 362 post(s)
Please avoid any old tyre centre.
Try and find a local professional 4-wheel "Hunter" or similar laser business.
captainhaddock
#8 Posted : 08 March 2019 22:02:55(UTC)
captainhaddock
Was thanked: 28 time(s) in 20 post(s)
2.0 Sport Graphite Limited Edition in Aquatic Blue
This space is intentionally left blank
GaryL
#9 Posted : 14 March 2019 18:35:08(UTC)
GaryL
Sorry thanks for all your replies, really useful.
I have now taken it back to the tyre specialsit 5 times and (although better) the wheel is still out of alignment. The place I took it SETyres in Epsom is usually very good but I think I may have waisted £30.
Does anyone know of somewhere to take this (maybe the Mazda dealer?) near me in Epsom Surrey?
GaryL
#10 Posted : 14 March 2019 18:35:11(UTC)
GaryL
Raymond Harper
#11 Posted : 14 March 2019 19:06:07(UTC)
Raymond Harper
Was thanked: 147 time(s) in 140 post(s)
Don't waste any more money. Take it back to one of them to get it fixed again properly. You have already paid for this.
This page was generated in 0.529 seconds.
