spotdoc67
#1 Posted : 14 March 2019 18:39:14(UTC)
spotdoc67
I've just been to see an early 1990 UK car which I might buy.
It's been off the road for 2 years.
There is a problem with the engine cutting out.  It fires up fine and runs for about a minute before cutting out. If you try to restart it will cut out almost immediately.
Any thoughts?
Could it be a fuel pump or fuel pump relay?
Tom
Combemartian
#2 Posted : 14 March 2019 19:08:51(UTC)
Combemartian
Was thanked: 74 time(s) in 68 post(s)
Blocked fuel filter maybe? The one under the car or the one on the bottom of the fuel pump.
Put a link between FP and ground in the diagnostic port, turn the ignition on and listen for fuel being pumped round. If you feel brave you could remove the pipe to the fuel rail, fit another pipe down to a container outside the car and check the flow.
Good luck
D
Edited by user 14 March 2019 21:44:01(UTC)  | Reason: Not specified
2011 mk3.5 metropolitan grey
1995 mk1 chaste white
#3 Posted : 14 March 2019 22:20:57(UTC)
Was thanked: 685 time(s) in 604 post(s)
I had similar symptoms with the fuel injector relay. It sits in the main fuse box, and the one I took out was completely rusted inside, so possibly its location exposes it to the elements.
Check the air flow meter flap is moving freely.
Guest (3)
This page was generated in 0.256 seconds.
