Mr_Sukebe
#1 Posted : 06 December 2018 09:23:58(UTC)
Mr_Sukebe
Was thanked: 17 time(s) in 14 post(s)
Filled my car up at the local Shell this morning, and I have a cm of water in the recess, where the fuel filler is on my NB.
I'm assuming that this is meant to drain somewhere.  Can someone advise where and therefore what I need to clear?
#2 Posted : 06 December 2018 09:42:36(UTC)
I've used a pokey tool (thin piece of wire or electrical wire) to prod down there. The drain pipe would come out I guess under the wing area, it's a while since I've owned a Mk2 but most cars have a drain hole in the fuel cap/flap area, my SEAT daily driver does although that doesn't seem to drain very well and I've poked some wire down there
Take care when poking
Dipstick
#3 Posted : 06 December 2018 15:54:38(UTC)
Dipstick
Was thanked: 154 time(s) in 135 post(s)
The drain tube runs from the bottom of the filler cap surround and runs through the boot next to the aerial. It can be accessed by removing the plastic tray on the left side of the boot and the removing clips for the lining on that side and pulling away. The drain pipe can then be pulled off and removed for cleaning if blocked.
2005 MX5 2.5 1800i ICON / Manual / Brilliant Black / UN05 AJW / South Central Member
NickD
#4 Posted : 06 December 2018 17:18:29(UTC)
NickD
Was thanked: 472 time(s) in 362 post(s)
Very wise!
Mr_Sukebe
#5 Posted : 06 December 2018 18:18:09(UTC)
Mr_Sukebe
Thanks guys.  Was basically completely blocked.
Took the opportunity when I got home to clean both it and the standard roof drain holes, so we're all good now, and action man#s jacuzzi is cleared.
Paul W
#6 Posted : 08 December 2018 17:02:24(UTC)
Paul W
Was thanked: 176 time(s) in 165 post(s)
For jobs like this I use a length of curtain hanging wire (the old fashioned, plastic covered, bendy stuff). It will go round corners well enough but there's nothing on the end to get jammed - so if it goes in, it should come out again.
Mk2 1.8i, built Jan 1998.
#7 Posted : 08 December 2018 17:07:54(UTC)
Very wise!
A number of successful professionals, most of whom happen to be male, have paid a significant price for not adhering to this excellent advice:-)
This page was generated in 0.294 seconds.
