alfordmazza
#1 Posted : 10 February 2019 10:06:17(UTC)
alfordmazza
Hiya eveyone.
Can anyone provide some advice regarding dash cams?  I'd like to get one for my Mk3.5 and another for my wife's Mazda 2.  Happy to go to around £50 each.  I'm quite drawn to the mirror and mirror mounted ones.
Thanks everyone, keep those roofs coming down
Mk5 mk3.5 2.0 stormy blue metallic
Pipercross panel filter
Racing beat exhaust
Mx5 2.5 1.6 crystal blue metallic
K&N Panel filter
Superflex Bushes
Larini exhaust. (Now with new owner)
SLK User is suspended until 03/05/2027 20:56:14(UTC)
#2 Posted : 10 February 2019 10:38:41(UTC)
SLK
Originally Posted by: alfordmazza Go to Quoted Post
Hiya eveyone.
Bit more than £50 but worth it.We run nextbase GPS/Wifi front and rear (2 cameras) on all 3 cars.Cost more than £50 though but simplicity of downloading over wifi to app & the benefit of sending straight to police and insurance.
I think you can get a standard Nextbase for about £48.What ever you bug get one that the screen turns off within 30 seconds.The rear on the 5 is fixed to the wind breaker so records roof up/down.All cars have Nextbases hard wired so no cables can be seen.Front cameras are hidden out of drivers field of view behind the mirror.32g micro sd cards in each.Every few weeks i just reformat to keep them running sweet.If we only used one car at a time,then i would have only 2 cams but purchase  an additional 4 GPS docking stations.Have them all hardwired & then its easy to just slide the Nexthbase on to any magnetic GPS dock depending on which car you take out.
Edited by user 10 February 2019 11:10:00(UTC)  | Reason: Not specified
 1 user thanked SLK for this useful post.
alfordmazza on 10/02/2019(UTC)
Mike-McD
#3 Posted : 10 February 2019 11:16:11(UTC)
Mike-McD
Was thanked: 40 time(s) in 36 post(s)
I've got a NExtbase312GW think it was about £80 - remeber your 10% owners club discount  if buying from Hlafords.
Mines works fine, although I damaged the screen so I no longer see anything on that, but it still records and I can download files from it no problem it / when I need to.
 1 user thanked Mike-McD for this useful post.
alfordmazza
#4 Posted : 10 February 2019 12:43:20(UTC)
alfordmazza
Regarding hardwiring of the dash cams I assume that they power on and off with the ignition  as not to drain batteries .
What sort of cost is hardwiring?
Racing beat exhaust
K&N Panel filter
Superflex Bushes
#5 Posted : 10 February 2019 14:45:50(UTC)
I bought something like this below and wired it in to the fuse box at the base of the A pillar passenger side, choose a connection that's live with the ignition on of course or the audio feed. Just make sure the piggy back fuse holder supplied comes in the same size as the Mazda fuses fitted and the micro usb connection is compatible with your dash cam conn.
https://www.amazon.co.uk/dp/B071WK122N/ref=asc_df_B071WK122N58441332/?tag=googshopuk-21&creative=22146&creativeASIN=B071WK122N&linkCode=df0&hvadid=310801248631&hvpos=1o1&hvnetw=g&hvrand=997902236737822814&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046420&hvtargid=pla-385905242338
Edited by user 10 February 2019 14:49:32(UTC)  | Reason: Not specified
#6 Posted : 10 February 2019 15:10:26(UTC)
I am looking to get dash cams installed on our cars in the near future. No rush as live in South Devon and very low mileage but they do make a lot of sense.
My better half bought a really cheap piece of CXXX off ebay which I was going to play with but the instuctions are so small, dark and badly written that I think I may just do us both a favour and throw the thing straight into the bin.
Nextbase have been well thought of for some years now with dashcams and there were some bargains around on ebay with the sales. Basic model with full wiring kit for under £50. I have a feeling that going cheap on these or rather inferior product will be a mistake so Nextbase it is then. These are not just install and forget as quality products will give you a better result with less input and be more reliable.
Flood
#7 Posted : 10 February 2019 15:22:18(UTC)
Flood
i have a garmin 55. Costs about £100 from amazon, and comes with a sticky metal disk that sticks to window for mounting.
Costs £5 for new disk so you can setup multiple cars for 1 driver and 1 dashcam easily enough
MK1 Eunos S-limited
#8 Posted : 10 February 2019 18:05:33(UTC)
SLK
Does not drain battery, power on/off with ignition & cost to hard wire is about £1.50 for a piggy back fuse.
trufflehunt
#9 Posted : 10 February 2019 19:41:13(UTC)
trufflehunt
Was thanked: 109 time(s) in 91 post(s)
A year past July, a 17 year old on a motor scooter chopped straight across my path on a roundabout. He was lucky I was at  a low speed, the side of his scooter took the impact, and he had a relatively mild tumble. . Gravel rash and cuts to his ankle and elbow. And some shock.
That is when I decided to obtain a dash cam.
First I bought a cheap eBay dash cam at £9.95. Same shape and appearance as the basic Nextbase 112 model. Similarity ends there.
I put the video up on Youtube. At a throwaway price, it does a job. Annoying audio rattle...., I never kept it long enough to track down the cause.
Then I bought an Old Shark 1080p model. Currently on Amazon at around £45.
An impressive and solidly built piece of kit with a good lens,
and metal body.
After thinking things over, and considering that with just a soft top between the camera and light fingers,
I realised that whenever I parked up the MX5 for a while I'd need to remove the dashcam.
I therefore decided to buy a Nextbase 312GW because it had a magnetic mount.
This means that I can leave the suction cup mount permanently on the screen, rather than have to either
unscrew the camera from a screen mount, or remove the suction mount itself.
The 312GW has much the same quality video as the Old Shark. with the addition of GPS, so that all
your speeds are on record. A possible double edged sword. .
Edited by user 10 February 2019 19:51:16(UTC)  | Reason: Not specified
1993 MX5 Mk1 1.6 UK Car
2002 VW Golf 1.9 TDI
guinnessman2001
#10 Posted : 10 February 2019 22:01:53(UTC)
guinnessman2001
Was thanked: 24 time(s) in 24 post(s)
I similarly went down the cheap ebay route and fitted one at under £10. Picture playback quality was terrible, you could hardly read number plates even stopped behind a car at traffic lights.
So that just went in the bin.
Then bought an Apeman Model CS70, it was only around £40 from Amazon. I hard wired it in through a piggy back fuse and 5V step down transformer module, fed the cable up inside the passenger A pillar, because I located the step down module behind the glove box.
I used the cigar lighter, ignition powered, for the piggy back.
I would definitely recommend this model, records in full 1080 HD and has wide angle lens, motion sensing and G sensor.
Also fitted one in my M3, and viewing playback on my pc is superb, even at night in reduced lighting.
It's also easily removable if you are parked up with the top down, it just unclips from the suction mount.
2003 MX5 1.8 Sport Silver,hard top,air con, reversing sensors, footwell LEDs
2003 BMW M3 Carbon Black,digital TV, sat nav,
DonT
#11 Posted : 10 February 2019 23:38:11(UTC)
DonT
Was thanked: 440 time(s) in 428 post(s)
I have a 55 too, bought it from Halfords, they hardwired into my 107 and 10% off device and fitting. Going to get my Mazda hard wired in April & use the one device in the two cars.
1995 Mazda MX-5 1.8 iS in Classic Red
Winner Standard Mk1 Donington Park National Rally 2016
Winner Standard Mk1 Kelmarsh Hall National Rally 2015
Owned since April 2002
Club Member since April 2002
Nurburgring & Stelvio Pass
BMW 330D M Sport
Peugeot 107
Featured in Modern Classics January 2019
safetymatch
#12 Posted : 11 February 2019 05:32:13(UTC)
safetymatch
Was thanked: 225 time(s) in 202 post(s)
Nextbase 410 in my works van which can do 300 miles a day, it gives you a secure (if that's the right word) feeling that if anything goes wrong you have it covered.
It also calms your own driving down because you don't want to be shown as the idiot who caused the crash....or worse.
Marble White icon
GPS tracker fitted
Lang'd to WIM spec's
Ex 2.5vvt sport
Stebel horn
Vented bonnet
Suzuki Jimny,fun!
Flood
#13 Posted : 11 February 2019 18:46:32(UTC)
Flood
Thats what i plan to do later in year.
How much do halfords take to hard wire if not buying dash cam at same time?
MK1 Eunos S-limited
DonT
#14 Posted : 11 February 2019 19:41:23(UTC)
DonT
Can‘t really remember, it’s not too much though.
BMW 330D M Sport
Peugeot 107
This page was generated in 0.762 seconds.
